Endless loop after replacement of lightning
After replacing lightning connector, battery , display and wifi modul the iphone is stuck in endless loop.
Restore through pc works fine, but afterwards the phone goes back to endless loop.
I had to change the front camera and display cable cause i damaged it at first. Also had to change the wifi modul cause i damaged that too.
What i tried:
Disconnecting battery and plugging iphone : still endless loop
Disconnecting lightning connector and startin phone with battery: still loop
What might go wrong:
Pins? I accidentally bent the lightning connector ones but gently nudged them back in the right shape.
Malfunctioning parts? I bought brand new from shop.
Any ideas what might i be able to do to fix this?
Это хороший вопрос?
Счет 0
Добавить комментарий
