Why the touchpad is not working
The touchpad is suddenly stopped
Это хороший вопрос?
You probably accidentally pressed a one of FN F1-F12 combination. A list of Toshiba FN keys that allow you to activate a range of features on your laptop listed below. The one you want is probably "Fn-F9":
I hope that helps.
Был ли этот ответ полезен?
@beletetenaw you are not telling us what you have checked and if this just happened all of a sudden or if anything preceded this.
first check to make sure that the Touchpad is enabled. To re-enable your touchpad:
On your laptop keyboard, press the Fn key and the F9 key at the same time.
Now check to see if it is enabled.
If that does not work you want to make sure that you have the proper driver. Since we don't know which OS you have (Windows?) it's difficult to tell you which driver you have to get. Definitely update the driver according to your OS.
Now, if none of that works, you may just have a bad touch pad. If so, time to replace it. Since iFixit doesn't yet have a guide for that, use something like this video
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 29
За всё время: 694
2 Комментариев
Why is my mouse pad not working
из Duane Nelson
@duanenelso51585 what do you consider the mouse pad to be? The computer really only has a touch pad.......
из oldturkey03
