Четырехъядерный процессор Intel Core i7 с тактовой частотой 2,2 ГГц (ускорение Turbo Boost до 3,4 ГГц) или 2,5 ГГц (ускорение Turbo Boost до 3,7 ГГц) и 6 МБ общей кэш-памяти L3.
Battery fully charged voltage low
The top battery charge voltage on my MacBook when the charge reaches 100% is just about 12.11 V, when it should be close to 12.6. I have replaced the battery there times, swapped chargers, reset SMC, PRAM, etc., and nothing fixes the issue. After about four cycles the newly replaced batteries health drops to the order of 60%. The first time I thought the replacement battery was faulty, but every new replacement battery, even from different vendors (including iFixit) did the same. I believe the trouble lies in the circuit or firmware that determines the maximum safe charge voltage and never lets the batteries reach their peak capacity. Any ideas about how to fix this issue?
Update (05/25/24)
Dear Dan,
I followed your instructions and the MacBook behaved as you indicated, but this procedure did not fix the MacBook manufacturing date. It still says 2024-11-11 (please see CoconutBattery display below).
You indicated that the batteries charge level issue is likely an issue within the SMC comparator logic (2 resistors often get damaged by knockoff chargers). Can you please advise where are these resistors located? Can I check them? (I have multimeter, oscilloscope, small soldering iron, and a friend has an SMD soldering station).
I never used a knockoff charger, but the original one started to heat at the Magsafe connector due to increased resistance on the ground lead caused by cable wear, heating that corner of the MacBook. I eventually repaired it but maybe the heat damaged or unsoldered the comparator resistors, if they are close to the Magsafe connector.
Thanks for your help I really appreciate your dedication.
Best regards.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
I really need to see the data from CoconutBattery
Post a snapshot of the Apps main window here.
Update (04/23/24)
Very odd CoconutBattery output! Note the systems manufacture date is in the future! 11/11/24 and the batteries date is within reason 8/16/22.
We also see the Batteries Cycle count is quite high for a supposed fresh battery! Besides the Design Cap being in the very worn condition with only 60.2% (your voltage issue)
I think we need to first fix the EFI issue as it's clearly the root issue as the manufactured date of the system is hard coded and it's likely the cause of the battery issues as well as the SMC running code is within the EFI ROM too.
So... What has been done to this system that proceeded this? And what was the issue as well.
While the batteries charge level issue is likely an issue within the SMC comparator logic (2 resistors often get damaged by knockoff chargers) the Cycle count is a problem as that is a count held within the batteries BMC chip but its also cached within SMC so its possible this is a carry over from the previous battery.
Lets give this a try to see if we can get it to at least give us a better Cycle count value. Disconnect the battery with nothing connected press and hold the power button to fully discharge the logic board this is a hard reset of SMC, then just plug in the charger the system should spontaneously restart, let it fully restart and do a clean shutdown now plug the battery back in. Lastly take a fresh CoconutBattery capture did any of the settings change? Post it as well so we have it documented.
Был ли этот ответ полезен?
Счет 1
4 Комментариев:
Hi Dan,
Thanks for posting. I added the info from Coconut Battery to my question.
из
I will do what you indicate during the weekend and revert. Thank you very much.
из
@juanvicentefont - Well your battery’s health is still very poor! Are you able to get a fresh battery as that is the next step. The resistors are on the logic board, but you can’t truly measure accurately onboard, you’ll need to remove them. I’ll need to dig into my schematics and board view drawings to post images of both altered today.
из
Please keep in mind that this is the third battery pack. The two previous ones also lost their health very quickly and with the same symptoms. I don't think it makes sense to replace the battery until I find and fix the culprit. And I think that if the fault is fixed and the charging voltage goes up to the correct value, the battery will charge to the nominal full voltage, possibly achieving about 80% health.
из
Добавьте свой ответ
Juan Font буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 9
За последние 30 дней: 26
За все время: 446
