13-дюймовый алюминиевый корпус Unibody, процессор Core 2 Duo с частотой 2,0 или 2,4 ГГц.
Optical Drive Not Making Sound at Startup
Hey guys, weird issue. I just replaced the logic board on this MacBook, and now the optical drive makes no noise at startup. Before, you know, there would be a humming and clicking sound and eventually the Startup Chime. Now, just the startup chime. The optical drive works just fine. But, the old logic board will activate the optical drive at startup whereas the new one will not. Everything works just fine, and it doesn't seem to be affecting anything else, I was wondering why it's not doing anything. And, if this is a problem, how could I fix it?
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
Выбранное решение
@danj & @livfe - Turns out is was a firmware issue. My Mac’s firmware was at 1.2, and I needed to update it to 1.4. That’s all it took. The optical drive now sounds great at startup! It’s funny how some of the strangest issues have the most simple fixes!
Был ли этот ответ полезен?
Счет 1
What you are seeing (really not) is the pecking order of the drives is no longer set to check the optical drive first. Going into the Startup Prefs allows you to alter it.
Счет 0
31 Комментариев:
@danj - Where would I change these settings?
из
@jadonlyon System Preferences / Startup Disc / Unlock and highlight the drive ?
из
@livfe - No luck there :(
из
@jadonlyon I wish my 8 'funny' units were that easy to fix..... Love that sound of a mac bootup :)
из
@livfe - Never ever gets old :)
из
Показать ещё 26 комментариев
Добавьте свой ответ
Jadon Lyon буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 11
За последние 30 дней: 23
За все время: 375
