Контроллер V2 выпускается в различных поколениях. Вы смотрите информацию по 4-му поколению.
Button inputs mixing and matching
I was playing an online game and got so angry that I threw my favourite controller, 5 years old, on the floor full force. I regret it terribly.
I've opened her up many times to change worn out rubber padding. I opened her up again, saw nothing wrong except a broken metal weight on the lower left. Put her together. I use her on PC, so i checked the inputs and they were fine on windows. I check them in game and button inputs are mixing, I press SQUARE and the results with be SQUARE TRIANGE. Or I press R1 and Ill get R1, CIRCLE and CROSS output results. I suspect the green motherboard inside is faulty or needs a replacement? What do think?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
A broken metal part might have caused colateral damage to the PCB that would require careful inspection with a glass to find.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Athi Musoke буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 11
За всё время: 196
