Problem with AC Alto K10
Getting hot air while using Air condition in Alto k10. What could be the reason for the same and how to fix it. Please suggest 🙏
Это хороший вопрос?
Это хороший вопрос?
@anirudh2022 the very first thing you want to check is to make sure that you have enough refrigerant in your AC system. The issue with the Alto system is that it is a small system and you got to be careful if you get a recharge kit, that you do not overcharge the system. It is probably best to get the AC system fully evacuated and then recharged with the correct weight. For that, you might need to find someone who deals with AC in your area. The only other thing you need to check is your condenser (looks like a radiator in the front of the vehicle) and make sure that the fins are clean and that there is no debris etc. that impedes the air flow.
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 10
За последние 30 дней: 41
За все время: 1,729
تركيب كهرباء سيارة الطو
из Rebîdj AEk Поделиться
@rebidjaek If this is a question, then you will need to add lots more information to it. Make , model and year of vehicle? What electrical installation?
translate
@rebidjaek إذا كان هذا سؤالاً، فستحتاج إلى إضافة معلومات إضافية. نوع السيارة، طرازها، وسنة صنعها؟ ما هي التركيبات الكهربائية؟
из oldturkey03 Поделиться
Fiyul motar problam
из Prince Rana Prince Rana Поделиться
Not coling
Only fan
из jignesh bhogayata Поделиться
@jigneshbho50971 same as my original answer.
