Blue screen error problem due to RAM
Blue Screen error problem due to RAM
Это хороший вопрос?
Это хороший вопрос?
@prayag57802 since you are certain this is caused by a bad RAM module, it is time to change it. Of course, you can also try and clean teh contacts first. I use a pencil eraser to clean the contacts. Also, inspect the RAM slots on your motherboard to make sure that there are no bend or corroded pins etc.
To work on your computer use the Dell OptiPlex 790 Desktop Owner's Manual which essentially is the service manual. Now, if you are just guessing that this is a RAM error, then you have to give us more information about what your computer is doing and what you have tried.
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 14
За все время: 294
Hi @prayag57802,
Did you change/increase the memory?
If so what type and how much memory did you try to install?
Also if you added more memory, does the PC work OK with the original memory that was installed?
из jayeff Поделиться
