Выпущенный в июле 2018 года 15-дюймовый MacBook Pro, модель A1990, оснащен 15,4-дюймовым дисплеем со светодиодной подсветкой и технологией True Tone, сканером Touch ID и 6-ядерным процессором Core i9 в топовой конфигурации.
Need help diagnosing display issues
My 2018 MacBook Pro display is shpwing flickering green and red lines, and occaionally blacks out or has a block pattern. I cannot locate any cracks in the screen, and the laptop has not been dropped since I have owned it. Graphics display perfectly when using Airplay to cast to my TV. Does this seem to indicate a display cable issue, or should I be looking at replacing the screen? Thanks in advance for the help.
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Выбранное решение
This is most likely due to a failing display flex cable, which unfortunately is integrated into the display assembly. This is a common design problem with these models (2016-2018ish Pros). Unfortunately you'll need to replace the display assembly to repair the device. Sorry!
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
That’s what I thought originally, I just needed some confirmation before I under the process. I already bought a replacement display as simply, I just had not installed it. If there was any other options, I wanted to explore that first. Thanks a bunch!
из
Saludos que me recomienda MacBook Pro 2018 15 pulgadas modelo a1990
Счет 0
Добавьте свой ответ
Tanya Robinson буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 23
За всё время: 259
