Xbox 360 — вторая игровая консоль от Microsoft, выпущенная 22 ноября 2005 года.
Help with open tray error?
So I recently bought an XBOX 360 and I keep getting open tray error. I replaced the laser (I removed the solder blob from the replacement) but I still get the same error, only this time the laser seems to atleast try to read the games. I took it apart to try and see whats the problem, and I saw that sometimes when I insert the game the laser lights up for a second and then goes out right before the disc starts to spin, and than stops and does that for 4 to 5 times before showing open tray error once again. Other times the disc spins up, the laser lights up and moves and it tries to read but ultimately ends up with an open tray error. I heard that you can try tapping the drive in hopes of getting it to work, so I tried it and got the drive to read the disc twice so far but the console did not recognize what game it was, I either got "Unrecognized disc" error or the console just froze. I've been trying to get the console to work for like a month now but to no awail. I'm out of ideas... I tried with like 15 different games (Kinect, XBOX Classic, and normal Xbox 360) games and neither of them worked. I'm open to any suggestions.
PS.: It's a 2008 Phat
UPDATE: I got the thing kind of working, it reads games when I'm gently tapping the drive while the console is opend up after a few attempts, the game shows up, starts and after like 5-10 seconds it stoppes and I get a "unrecognized disc" error. The disc is still spinning. When it starts to read the disc, the laser seems strong but by the time of the crash it seems like it's a lot weaker and it weakens till it isn't visible. Should I mess with the pot or nah? I've seen people suggesting tweaking it for replacement lasers since it's not set properly by default but I don't have a multimeter.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi!
Okay, it does sound like that the replacement laser is faulty. But, you also got the open tray error right? Did this happened after you replaced the laser?
What you can do is the following:
  • get a new xbox 360 drive and replace the PCB of that one with yours. Test if it works now.
  • You can also replace the laser deck. This is easier and you’ll replace multiple components at once. But the sensor (which can be faulty) will not be replaced….
I would recommend to get a new drive, if this is not possible or too expensive, then replace the laser deck and try to see what happens.
In the worst case, there is something wrong with the PCB, but lets try that first.
Please let us know how it goes!
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
I don't think the replacement would be faulty, just minutes ago I got the thing reading an XBOX Classic game, it didn't run cuz it said it's not supperted but it showed the title of the game and shown the xbox classic logo when I tried to play it. I was messing with the height adjusment since I didn't have a better idea. It isn't working but it's trying.
Also I tried looking for another drive, but noone is selling any used and I don't want to order one, it will take another month or so just for the thing to arrive and I'm not even sure whats wrong with it
PS.: It was like that before the replacement too.
из
Okay, as it was already like that before the replacement,,, the laser should be fine yes. Did you adjusted the laser it's potentiometer? Maybe this is needed to read the games again. Yeah, in the worst a drive replacement is needed... Hopefully you'll find one, if you can't get the laser working..
из
Добавьте свой ответ
Purple буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 9
За последние 30 дней: 37
За всё время: 683
