Контроллер Xbox One был представлен в 2016 году одновременно с выпуском Xbox One S и получил поддержку Bluetooth для Windows 10/11. Этот контроллер исправляет многие конструктивные недостатки моделей 1537/1697 и отличается гораздо большей надежностью. Данная модель была заменена улучшенным контроллером модели 1914.
Left Stick Constant Input Down
I attempted some maintenance on my controller a couple of weeks ago, using some 99% IPA to scrub the potentiometers of the joysticks to my controller, as well as the joysticks themselves, and other areas of the motherboard. However, as a result, the left stick has been constantly giving input downward according to the direction of the stick.
I have attempted to clean the potentiometers again, as well as replace the left stick just today, to no avail on resolving this new issue.
Upon testing for continuity, I noticed that the pins in the potentiometer intended to input vertical LS movement do not seem to have a connection. This is after clarifying that all of the opposite pins on all three of the other potentiometers in the controller returned a status of continuity existing between them respectively.
I am wondering, then, what the problem could be with the controller. Thank you for reading into my inquiry.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi Aiden!
How are the solder pads? Still good? If those are damaged it can cause the issue you are having.
Also, check the other components near the sticks on the motherboard, maybe something is damaged there.
Please let us know how it goes!
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
Hi there, what could I do in the event that the solder pads are damaged? How could I bring the controller back to operation in such a case?
из
Depends on how it is damaged! Can you remove all the solder and sent us a new photo? Thanks in advance!
из
Добавьте свой ответ
Aiden буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 13
За всё время: 264
