Repair information and guides for the long-awaited refresh of the popular MacBook Air, featuring Intel's Core i5 processors, an updated Retina Display, and numerous other changes and updates that was released on November 7th, 2018.
Identify capacitor for replacing
Hello
I'm looking for some help identifying a capacitor that's blown so I can order another and replace it. It's on a A1932 MacBook logic board and the capacitor number is C6415, I will attach an image of the schematic where its located.
Thanks in advance
Это хороший вопрос?
Счет 0
1 Комментарий
Do you have the schematics for this system? You should be able to locate it by its number and it will offer the caps info. I’m just stepping out if you don’t have it let us know and I’ll try to find mine.
из
Добавить комментарий
1 ответ
Выбранное решение
The device you posted the question under is the MacBook Air 15" but you state this is for the A1932 model, which applies to the 13-inch 2018 and 13-inch 2019 model MBAs. If it is indeed the A1932 model, then here is the information regarding that capacitor (see attached image). You may be able to purchase a same-spec capacitor online via aliexpress or mouser or another electronic component retailer. Good luck!
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
It is indeed the 2018 13" model, I selected the wrong one. Thank you very much for your help
из
No worries! Good luck!
из
Добавьте свой ответ
YEET_ буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 9
За последние 30 дней: 25
За всё время: 264
