iPhone SE 3-го поколения был анонсирован 8 марта во время мероприятия Apple «Peek Performance». Он оснащен процессором A15 и 4,7-дюймовым ЖК-дисплеем, как и его предшественник, iPhone SE 2020 года.
Replaced screen but not working
Old screen now not working either
All connectors look fine
Please help
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
Выбранное решение
So after doing some googling it was as simple as doing a reset, it has now sprung into life.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Awesome, Justin; glad to hear it was something simple.
из
Наиболее полезный ответ
Hi Justin,
You've got an iPhone with a screen made with older LCD technology, which means it has a backlight. It would be worth your time to check to see if the backlight has failed. Take a flashlight and hold it up against the screen and see if you can make out an image. If so, you may have blown a backlight fuse on the motherboard, which would be a tricky repair for us home DIY-ers. That sort of thing usually happens when the screen is connected or disconnected while the battery is plugged in; it rarely is a problem when the battery is disconnected before working on the screen.
Check that out and let us know what you find.
Does the phone appear to be alive in other respects? Does it make any sounds or vibrations when turned on or connected to a charger? Is there a response when plugged into a computer; does the computer recognize that it's there?
Счет 2
1 Комментарий:
Thanks for your help, but all it needed was a reset.
из
Добавьте свой ответ
Justin Short буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 12
За всё время: 439
