Why does my iPhone keep restarting?
Every time I open my iPhone it will stay on for a short period of time and then restart. Sometimes when it’s on charge it will last longer but most of the time I get less than a minute of use before it restarts. It either restarts to 10% or 1% when turns back on and then after a few more it will go back to what it was at before. It only changes charge by a large amount when it takes a long time to turn on. It doesn’t restart when I’m searching on on a browser, sometimes it restarts when I’m on YouTube and it always restarts quickly if I’m playing a game
Это хороший вопрос?
Счет 0
4 Комментариев:
Hey, I’d start by checking the battery health to see what percentage performance you’re at. Below 80% is definitely a battery change.
из
It’s at 89 and the entire back is shattered. I check the panic logs but couldn’t find anything
из
Gee that’s no good, the only way to quick test is pull motherboard out & test in an un damaged donor phone. Apart from unknown device prompts if it functions then you can start to look at troubleshooting your assembly components.
из
If it does the same on donor phone back assembly then there’s an issue on your mainboard
из
Добавить комментарий
