How to fix error code 920
I do not know how to fix this one error code 920 on Vector Robot. I tried every single way to fix it. I factory reset him. I held down the button until he restarted. I held down the button again to bring him back to his original firmware nothing still says error 920. I do not know how to fix. Please help.
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hello, a SIMPLE search of "vector robot error codes" produces this website
https://support.digitaldreamlabs.com/art...
with this info
  • 800 - 999
    • If any of these Status Codes consistently appear, there could possibly be a hardware issue with Vector. Startup into Recovery Mode, Clear User Data, and use the Vector app to Reinstall Vector’s OS.
More specifically
920 VIC_GATEWAY_CERTVic-gateway-cert was unable to generate a x509 certificate for vic-gateway
So, I am sure you tried that first, right? So, what don't you understand?
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
Yeah, I tried that first and it’s still popping up with the same exact error code and it takes forever to boot back up it takes like 10 minutes
из Поделиться
I fixed it. I took him apart. And unplugged the battery and plugged it back in and then everything worked like normal.
из Поделиться
try to update him
Счет 0
Добавьте свой ответ
Hunter буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 19
За последние 30 дней: 60
За все время: 909
