Информация по ремонту и руководства по разборке сушилок Electrolux.
Electrolux dryer power button delay
My EDC2086PDW was bought about 2018. Lately it has often been slow to react when we press the power (on/off) button. It usually powers on after pressing this button for about a second, but now it sometimes needs longer pressing. Occasionally more than 20 (yes, twenty!) seconds.
Anyone with a similar problem, and possible fix?
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
My first thought for the increasing delay is contamination buildup on the start button. I would start by insuring that the button and area around it is clean. Then, if the button is replaceable, I would replace it. If it is part of an assy, then insure that the whole assy is free of corrosion or other contamination b4 replacing it.
Был ли этот ответ полезен?
Счет 0
Em português por favor
Счет 0
1 Комментарий:
Teria sido mais fácil para você usar o Google Tradutor Meu primeiro pensamento sobre o aumento do atraso é o acúmulo de contaminação no botão de partida. Eu começaria garantindo que o botão e a área ao redor estejam limpos. Depois, se o botão for substituível, eu o substituiria. Se fizer parte de um conjunto, certifique-se de que todo o conjunto esteja livre de corrosão ou outra contaminação antes de substituí-lo.
из
Добавьте свой ответ
Marius M буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 17
За всё время: 311
