Беспроводной контроллер Xbox Elite Series 2 был выпущен 4 ноября 2019 года и совместим с консолями Xbox One, X и S, а также с ПК под управлением Windows 10/11. Модель 1797.
Non-responsive with battery connected
Have a strange issue. My elite 2 controller is completely non-responsive when the battery is connected. Won't power on, charge, or anything. BUT it works when plugged in via usb without the battery connected. As soon as I reassemble the back plate and connect the battery, the controller is completely dead.
Useful diagnostic info:
  • battery is delivering power and not damaged
  • no liquid damage to controller
  • no visible corrosion on battery connectors
What is going on????
Это хороший вопрос?
Счет 0
2 Комментариев
Are you using a battery pack? Or just 2 AA batteries? Did you tried both to test the controller? Is the controller up to date? When using a battery pack, which brand? The one from Microsoft?
из Поделиться
This is an elite series 2...the battery is built-in, not AA replaceable. The battery is original.
из Поделиться
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hi Matthew! Sry! Okay the easiest thing to try is a new battery pack and see if that solves it! If not, it’s motherboard related. Controller is up to date?
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
The controller is up to date. I just put the controller back together and while securing the back plate onto the board housing the controller turned on. Once I screwed the back plate onto the housing completely, the controller is now no longer responsive. Could there be a faulty or loose connection? The three pin battery terminal doesn't appear damaged.
Thoughts?
из Поделиться
Hi! Could be, or something is causing a short. Can you check if the screws are not touching the motherboard? Also check the cables to see if they are free when closing the back plate.
из Поделиться
Its possible you are screwing the screws too tightly wgen you reassemble the controller. Try to loosen them a little. It might work
Счет 0
1 Комментарий:
Any fix? I have one with the same problem
из Поделиться
Добавьте свой ответ
Matthew Riordan буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 6
За последние 7 дней: 14
За последние 30 дней: 56
За все время: 620
