Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
Display Touch NOT responding?
Hey. i have 2 Displays thats like Brand New. BUT the touch not responding att all. What can be the Problem? When i touch it the light goes on. So the displays are reacting on that way tho?
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Hi Markus,
If the problem persists even after installing a working/tested screen, then the problem is with the motherboard. You will have to check the ground resistance of the touch connector and compare it with another iPhone X or in ZXW software, trace out missing/short connections and fix the problem.
BR
Francis
CelMetro
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Markus буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 8
За все время: 130
