Raspberry Pi 4 — это универсальный одноплатный компьютер, разработанный Raspberry Pi Foundation. Он является четвертой итерацией линейки продуктов Raspberry Pi.
USB ports are dead
Hi guys. I have a RaspberryPi 4B 4GB (newer version) that had 9V instead of 5V put through the USB-C power input according to owner.
Surprisingly it boots and works, but ethernet and USB ports are dead. I replaced the BCM54213PE and VL805 chips I took from a donor board - ethernet works fine now, but no luck with USB.
I also replaced the crystals next to both of those chips - didn't help either.
Any ideas what else I should check?
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Выбранное решение
Fixed it in the end :) So in total I replaced both chips and also quartz crystals next to them on both sides, then also replaced a diode next to the Ethernet port and USB 3 and two chips that look like filters between the BCM54213PE and PoE.
None of that actually did the trick in full, so then I reflowed VL805 IC and voila - "we have picture" (c) Sorin :D
Был ли этот ответ полезен?
Счет 1
Did you post your question in the Raspberry Forum area?
I would check the power side of the USB sockets is power getting through? Does a powered USB hub allow the USB device to work?
Счет 0
1 Комментарий:
Oh absolutely, thanks, but actually I already figured it out :) thanks for the heads up anyway :)
из
Добавьте свой ответ
in_sympathy буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 24
За последние 30 дней: 83
За все время: 1,107
