Resembles wiring back in order
Aroma 2022 > model ARC 1030SB, I kept having bad horrible burnt smell so I decided to disassemble to figure out what was going on. I found that the hot plate had burnt waste under it and in the inner bowl like very bad. So I clean it and now well, try my best to put it back. But can’t seem to remember the way the wires r suppose to be. I tried to put the wires how I thought they should go, but when I go plug it in, and press; a cook button it turns off. So struck in this part. Help! Other rice pot old YouTube videos haven’t not help whatsoever. And can’t seem to figure out where (heat) wire should go. Cause there also ACN & ACL (the ACL is connect w the power plug. Like in which order am I supposed to put the wires that go screw in, on the hot plate. Cause the black one by its self that reads (Heat), blue wire that is by its self and reads ACN. Finally the red wire attached with the, plug in and it switches out to black wire w a white cushion on it reads ACL. So in which order should I put these?? Help?? And I been trying to upload pictures but system won’t let me.
Это хороший вопрос?
Счет 0
Добавить комментарий
