12 volt Viking jump starter
It should be changed but it keeps beeping and says that the battery is dead on the jump starter. What should I do?
Это хороший вопрос?
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 8
За всё время: 181
This question was migrated from https://meta.ifixit.com/Answers.
из iRobot
Most low cost portable battery boosters/jump starter use a sealed lead acid battery with a limited life. Better, more expensive ones use lithium batteries and may last longer. If kept charged periodically, they may last longer than 5 years. If you can disassemble your jump pack, you may find specs on the battery to see if its worth replacing, presuming the electronics is intact or buy a new jump starter.
из F Dryer
