Эта итерация серии электронных книг Amazon Kindle Paperwhite была выпущена 30 июня 2015 года. Kindle Paperwhite 3-го поколения представляет собой 6-дюймовый планшет для чтения с дисплеем 300 PPI и поддержкой Wi-Fi. Номер модели — DP75SDI.
My screen is stuck at language setup screen.
Hi Team,
My Kindle was stuck all the time on home screen.
When I press power button it would popup option to restart, shutdown cancel however I was never able to select it.
Out of frustration I followed an article on Internet "Doing Factory reset using computer"
I created File without extension Do_Factory_Restore transferred to kindle performed factory reset.
Now my screen is stuck at language setup page.
  • I am unable to select get started 😑
  • I tried pressing hardreset for 40sec no joy.
  • I tried connecting kindle to computer it shows drive is not ready😓.
  • I have put my self in helpless situation.
Это хороший вопрос?
Счет 0
3 Комментариев:
Is the touch screen working? It could be a screen issue.
из
Touch works on limited area rest feels like screen Is dead
из
It’s possible half the screen is dead , most probable in-fact as it’s a strange screen to be stuck on. Have you dropped it any marks or damage on or around the screen? I’m weirdly convinced my below answer will fix this.
If your not confident you could always take it to a repair shop for second opinion/ repair.
из
Добавить комментарий
2 Ответов
If you cannot do anything on the screen it is most likely a damaged digitiser. This can get damaged by a short fall or bump in the wrong place . Here’s a full guide and what to get.
Замена сенсорной панели экрана/дисплея Amazon Kindle Paperwhite 3-го поколения
Был ли этот ответ полезен?
Счет 0
Try to turn off the screen using the power button and long-press it for a few seconds. If this doesn't work then try charging it for sometime. Restart your Kindle to resolve the frozen issue.
Счет 0
Добавьте свой ответ
Ashley John буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 10
За всё время: 330
