Информация по ремонту и руководства для обновленной версии Retina MacBook 2015 года, выпущенной в начале 2016 года. Модель A1534 / EMC 2991
Force Trackpad Weak After Assembly
Hey all at iFixit.
I am working on this MacBook, and I have been using it for a few months now without any issues. Yet, I couldn't help but notice that the force trackpad was very weak. I could hear the click, but I could barely even feel it. I took the machine apart, but the trackpad felt fine. After a snapped the lower case back on, the trackpad became weak again. Something happens when I snap the lower case on, and the trackpad loses power. I feel like something might be bent on the lower case, but nothing appears off.
Should I look somewhere else? Why would the trackpad lose power by simply putting on the lower case?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
I would take a straight edge to see if the case is not caved in either side. Also check if the case is warped so diagonal corners appear to not lay flat on a known flat surface.
If you don’t detect any issues then I would summarize the TouchPad is damaged and will need replacement.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
@danj - Turns out the lower case was bent a little, I took some clamps and bent it back in place, trackpad feels great now!
из
Добавьте свой ответ
Jadon Lyon буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 15
За все время: 213
