Ведущий представитель iPhone 2020 года от компании Apple был выпущен 23 октября и поставляется с 6.1-дюймовым OLED-дисплеем, 12-мегапиксельной двойной камерой и доступен в 5 цветах. Преемник iPhone 11.
Kernel Panic Missing sensor(s)
Missing sensor(s)
Update (09/07/24)
"panicString" : "panic(cpu 2 caller 0xfffffff02c62b8e8): userspace watchdog timeout: no successful checkins from thermalmonitord\nservice returned not alive with context : is_alive_func returned unhealthy : current 5fffffffff, mask 3fffffffff, expected 3fffffffff. SD: 1 BC: 1 RC: 0 BS: 1, Missing sensor(s): Prs0 \nservice: backboardd, total successful checkins in 194 seconds: 19, last successful checkin: 0 seconds ago\nservice: SpringBoard, total successful checkins in 169 seconds: 17, last successful checkin: 0 seconds ago\nservice: mediaserverd, total successful checkins in 194 seconds: 18, last successful checkin: 0 seconds ago\nservice: logd, total successful checkins in 194 seconds: 19, last successful checkin: 0 seconds ago\nservice: thermalmonitord, no successful checkins in 194 seconds\nservice: runningboardd, total successful checkins in 194 seconds: 19, last successful checkin: 0 seconds ago\nservice: wifid, total successful checkins in 194 seconds: 18, last successful checkin: 0 seconds ago\nservice: configd, total successful checkins in 194 seconds: 18, last successful checkin: 0 seconds\nDebugger message: panic\nMemory ID: 0xff\nOS release type: User\nOS version: 20H115\nKernel version: Darwin Kernel Version 22.6.0: Wed Oct 4 21:55:46 PDT 2023; root:xnu-8796.142.1.701.11~1\/RELEASE_ARM64_T8101\nFileset Kernelcache UUID: C5D2A5F46EB1E5A63AF8FDE73B4AD5E9\nKernel UUID: 510BBA43-3466-3323-88BD-6B231BB89712\nBoot session UUID: E97F1F8E-97D5-4524-9CA0-BAE7D1C681B7\niBoot version: iBoot-8422.142.2.700.1\nsecure boot?: YES\nroots installed: 0\nPaniclog version: 14\nKernelCache slide: 0x0000000023fa4000\nKernelCache base: 0xfffffff02afa8000\nKernel slide: 0x0000000023fac000\nKernel text base: 0xfffffff02afb0000\nKernel text exec slide: 0x0000000024d14000\nKernel
Update (09/07/24)
Update (09/07/24)
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Tarun (@tarun66510), it would help if you could confirm that we're talking about the same model phone as the original poster, since you cut off the beginning of the log showing that information.
Anyway, I can't tell offhand if these are three separate log entries, or if you've just posted the same one three times; either way they all say the same thing so only one is really needed.
Now when we take a look at the log itself we see exactly what was in the original poster's log, that the PRS0 pressure sensor has failed. So the fix for you is exactly the same as the fix for the original poster; replace the charging port assembly. Read my previous answer for details. Restart every 3 minutes after water
Был ли этот ответ полезен?
Счет 1
Hapus semua data panci full
Счет 0
Добавьте свой ответ
Tarun буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 59
За все время: 731
