Руководства по ремонту, разборке и устранению неполадок для беспроводных наушников с активным шумоподавлением AirPods Max, обновленных в сентябре 2024 года с новой зарядкой USB-C и в новых цветах.
Is wired audio possible?
Hi iFixit team,
A lot of users of the USB-C AirPods Max, myself included, have been surprised to find out that currently there is no support for wired connectivity with this model. Apple offered wired connectivity for the Lightning version through an Apple exclusive cable, but as of yet there is no such offering for the USB-C version. This has been confirmed with Apple Support.
My question is, can you tell if the USB-C port is capable of transferring audio or connected only to the battery, as some are speculating?
It would be helpful to know if this would ever be possible through software update/new cable, or if Apple has completely removed the possibility of wired audio connection for the new version.
Thanks!
Это хороший вопрос?
Счет 2
1 Комментарий
is there still a chance here? this is so upsetting, i live in a country where i can't do returns and turns out this thing is just all beauty and less functions.
из Поделиться
Добавить комментарий
2 Ответов
Выбранное решение
Hello 👋🏼
I saw your question and thought I would give an update on this. You can do this now with USB C and another cable that is a c to 3.5.
https://support.apple.com/en-us/108364
Был ли этот ответ полезен?
Счет 5
3 Комментариев:
Thank you! There's hope. I updated the AirPods Max firmware to the listed version to try this out. I tried a couple usb-c to 3.5mm cables I have, and neither worked. Really hoping I don't have to buy the 1st party $39 cable to get this feature.
из Поделиться
unfortunately, as of october 2026, that appears to still be the case. let's hope that changes in the future, cause the airpods max, as far as i know, use a different audio standard than your average headphones. most headphones are expecting an analog audio input, whereas the airpods max expect digital input, be it bluetooth or apple's fancy $39 audio cable.
из Поделиться
At one time during the Neanderthal age, Apple produced iPods(?) that did not allow replacement of rechargeable batteries. An entrepreneur in NYC tinkered with his, carefully disassembled it and found he could replace the battery pack and spread the news in forums. Once he let the cat out of the bag, iPod owners rushed to Apple and asked. Apple's response was when the unit fails, no provision of battery replacement was available. Most iPods suffered battery degradation after several years of regular use and basically needed a new battery but this kills Apple's bottom line if battery replacement became available. And now marketing for ear buds and headphones without cords seems to point in the same direction.
из Поделиться
The previous generation of Airpods Max could function in 'wired mode' with the aforementioned MFA Apple cable. As far as my understanding goes, there is no technical reason for this not to be acvhived with usb-c -> lightning.
The same applies here I suspect. There should be no reason why it cannot be done, it just depends on whether apple want to or not :/
My only regret regarding buying the airpods max (previous gen) is the fact that wired mode is essentially useless due to the requirement on an expensive (and incredibly fragile) cable.
Note to Apple: I have an Apple laptop, with an Apple usb c cable and Apple headphones. Make it work, you are being unreasonable. Grow up.
Счет 0
Добавьте свой ответ
drdogood буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 9
За последние 7 дней: 34
За последние 30 дней: 141
За все время: 6,023
