Apple’s new format for the 14 lineup features a 6.7-inch OLED—like the Pro Max—but the same features as the iPhone 14 with a dual camera setup and the Bionic A15 chip with a 5-core GPU.
iPhone 14 plus reboot randomly
Hello everyone, I'm posting a message here because my phone (iphone 14 plus) crashes and restarts by itself, I have the crash report, I need you to try to solve the problem, it's been like this for a month now, it's driving me crazy, I've switched back to the iphone 8 plus just long enough to understand, so if anyone has a solution I'll take it! https://pastecode.io/s/qoixm17c
Это хороший вопрос?
Счет 0
1 Комментарий:
Your iPhone may have a damaged battery, or it has a damaged. internal part. Maybe iOS itself is corrupted and needs to be restored, if that's the case then you will need to restore the phone using iTunes.
из
Добавить комментарий
1 ответ
I had similar issue, was under Apple Care, they rebuilt the entire phone. At a service center, it was great till Apple care ended, a few months.
Back to the same issue, random reboots and now randomly heats up.
Tried:
Removed protective case.
Turned off all background apps
Turned off app updates/refresh.
Deleted apps.
Do not carry in my pocket.
Bought a new Apple Charger/cord.
Do not use the induction charger any longer.
All this helped but still have the issue it is all random.
Do not expect a lot of help from Apple.
Irony, I traded up from I phone 11 with no issues, to the 14 plus, that was great for a few months.
Good luck!
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Matheo Maufroy буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 37
За всё время: 379
