Информация по ремонту колонок 2Boom.
Non destructive disassembly help BT488
I have this speaker from work I was tasked to try to fix, however I'm having issues getting into the chassis. Does anyone know the least destructive method to get in? I had picks all along the front face but wasn't able to get it separated far enough to see whatever else might be holding it in place.
The unit I have is simmer to the one linked but the non k model. the only difference I notice is the power switch.
https://www.menards.com/main/electrical/...
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
@tonyfriends sure looks like it is held together by 6 screws located at the front of the unit. Try to pop out the silver front bezel as well as the speaker grill. The screw pattern matches the bezel....:-)
While you work on your speaker, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Tony буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 12
За всё время: 255
