Model A1842. Released September 2017, the revision to Apple's 4th generation set-top-box featuring an A10X Fusion processor and 3 GB of RAM.
How do I replace / remove the Murata wifi/bluetooth module?
Do I have to de-solder the chip from the logic board? Is there any guide on how to do it?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Why are you doing this? The Apple TV won’t work properly without it. And you really can’t swap out the unit to something else.
You will need a hot air rework system to carefully desolder the chip. You should practice on some junk as it’s also easy to damage the solder pads underneath if you are not careful. But before you start assuming the chip has failed make sure you have the correct replacement.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Natalia Serene буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 20
За всё время: 254
