Этот смартфон Moto G с поддержкой сетей 5G оснащен 6,5-дюймовым ЖК-дисплеем с разрешением 720 x 1200 пикселей и частотой обновления 90 Гц, чипсетом MediaTek MT6833, а также широкоугольной камерой на 50 Мп, макрообъективом и датчиком глубины.
How to clean proximity sensor?
The display on the top side got unglued a few weeks back and I didn't bother to fix it. Now after ending phone call the proximity sensor turn off my display until I lock and unlock using buttons.
I believe it is due to some dirt accumulated on the sensor. What is the best way to clean it?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
I would run a hardware test on your phone to confirm this. There's a convenient iFixit guide for this. Secondly, you'll need to tear down the device a bit to clean it. I'm unsure if you'll need to remove the LCD panel, but there's a repair guide. You can clean it with some Q-tips and some isopropyl alcohol, but I can't give too much guidance on that.
If cleaning doesn't work, I can only recommend replacing the device's LCD frame or mid-frame housing. The mid-frame housing does contain some small components, potentially the proximity sensor. Also, it's essential to ensure you place proper adhesive post-repair.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Kishore Kumar S буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 14
За всё время: 370
