How do I tear it down
I need to know how to test it down
Это хороший вопрос?
Hi!
I think the most easiest way is to follow this guide: Замена материнской платы контроллера Sony DualSense v2
This basically tells you how to get to the last part. I know this is for the V2 controller instead for the V4, but the process is almost the same.
Был ли этот ответ полезен?
what is the diffrence bertween the v2 and the v4 coontroller?
Hi!
Minor differences. Just some other parts are used from another brand. Like the triggers and rubbers are slightly improved. No big changes.
Thats wrong. The whole motor/shoulder trigger assembly is different. There are no screws on the front side (where the buttons press against the board) and no metal axle for L2/R2 also the flex-connectors are just 3 pins
Hi! I'm sorry! You are correct! The difference between the V1 and V2 aren't that big. Later on they did start with the 3 pins! My appologies!
V4 has 4 wires instead of 2. also the flex cables are smaller.
За последние 24 часов: 8
За последние 7 дней: 97
За последние 30 дней: 398
За всё время: 7,519
