Руководства по ремонту и техническая поддержка видеокамер производства Panasonic.
How to fix a scratch lens
Hi, everyone, I have a couple of Panasonic camcorders in perfect shape other than I got a tiny scratch on the front lens on both camcorders, so when you record, certain ways the light enters the lens you see what looks to be a tiny bit of dust on your recording, and many people may not even notice it but I do a lot of filming and it bugs be crazy! Can I fix this without changing the lens which is nearly as expensive as the camcorder? Thanks for the help!
Update (12/09/24)
Panasonic HC-WXF1 and a Panasonic HC-VX1
Это хороший вопрос?
Счет 0
2 Комментариев
wow thanks for your help, but that first lens(7:51 marker) that's removed is all I need! Where can I get this?
Thanks again!
из
So you feel the steps would be the same to replace the same lens on a Panasonic HC-WXF1 camcorder?
Thanks
из
Добавить комментарий
1 ответ
Выбранное решение
@dmd31052 looks like you can get to the lens, but it is a bit of a PITA. See if something like {https://www.youtube.com/watch?v=1SLOYc4g... |this video] will help you to get to it. We'll continue to find some better material to assist you further.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
DMD буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 13
За всё время: 258
