Canon EOS Rebel T7, также известная как EOS 2000D, — это цифровая зеркальная камера с разрешением 24,1 Мп, выпущенная в 2015 году.
My Screen is cracked!
Is it possible to replace a screen window? It’s cracked, it’s not affecting the LCD itself & it works, but it’s just the fact that it’s cracked & bugging me. Is there a way to fix the screen, or anywhere I can take it? Many thanks.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
So just to be clear, it's only the protective screen cover that's cracked and not the screen itself? If so, it should be possible to replace it. That protective screen is held onto the back cover with double sided tape. The protective screen is called the TFT Window and the part number is CB5-3882. If the remaining tape isn't sticky enough after removing the window, you may also need to replace the tape. Often times the tape will be included if you buy a new protective screen, but if not, the part number for the tape is CB5-1039. Ideally you'd use the correct tape made for attaching the window to the camera, but you might also be able to use some other type of double sided tape if absolutely necessary.
I haven't done this repair personally, so I'm not certain on the proper way to remove the window. It might be possible to pry off the window without disassembling the camera at all, using something like a plastic pick (don't use anything metal). If it's not possible to just pry off the window without any disassembly, then this guide will show you how to disassemble what you need to in order to get at the window. It's for a different model, but the steps should mostly all match up pretty closely.
If you don't want to do the repair yourself, I'd imagine any camera repair shops that services this model of camera should be willing to do the repair for you as long as they are able to get ahold of a replacement window. If a replacement window can't be found, then the next solution would be to just replace the whole back cover, which would work, but also probably cost a bit more money.
Thin prying tool for opening electronic devices. Opening picks are essential to open any iPad, tablet, or smartphone sealed with adhesive. Изображение
Товар
iFixit Opening Picks (Set of 6)
$4.95
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
Callum Reynolds буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 16
За последние 30 дней: 49
За всё время: 864
