Беспроводной игровой контроллер в более традиционном стиле, выпущенный Nintendo для консоли Switch. Номер модели: HAC-013.
Botched Pro Controller Joystick Replacement - Is it salveable?
Hi everyone, I tried to replace the left joystick on my Nintendo Switch Pro Controller. Unfortunately, as the title says, I botched it. I managed to desolder most of the solder points for the joystick, but I still couldn't detach it.
In the process of trying to get any residual solder off the mounting pads, I partially ripped one of them. I think I need to get solder flux to try to get the remaining solder to flow to detach the joystick. However, I want to get the opinion of those more experienced to find out if I passed the point of no return before proceeding. Pictures are below.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
is it the bottom left in the photo
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
Yes it is. You can see the torn pad on the right side of the mounting points in the bottom left of the picture.
из
@smoothbrain looks similar to the pins above so i would say its a ground pin and fine to connect both together, so the bottom pin to the 1 just above with either a jumper wire or solder blob which ever is easier for you to do
из
Добавьте свой ответ
smoothbrain буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 15
За всё время: 339
