Руководства по поддержке и инструкции по ремонту ноутбуков HP Spectre с диагональю экрана 15 дюймов.
Replacement of laptop ssd
I want to replace laptop SSD but the screw of sed is worn out. It can't be opened. Suggest what to do.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
For stripped screws there are tools called 'stripped screw extractor' or 'spiral screw extractor' or 'speed out' or 'easy out'. There are a few different forms of the tool but they do the same thing: bite into the metal of the screw so you can unscrew it. They aren't expensive, you can find them on Amazon or other places. Make sure to get a set that has a very small one and you should be able to get the screw out. Then buy a pack of replacement SSD screws (you can also get those on Amazon) and you should be good.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
MAHENDRA SOLANKI буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 8
За всё время: 186
