Soldering iron tip storage
Is there a storage solution for the different/extra tips for fixhub soldering iron?
Это хороший вопрос?
Это хороший вопрос?
@leeperry67874 , we're working on something like this. In the meantime, maybe you might consider making a 3D printed option?
Был ли этот ответ полезен?
Unfortunately I don't own a 3d printer, but does a Hakko B2756 Soldering Tip Holder/stand work or is compatible with the FixHub Soldering Iron Tips for storage? or fit in the ifixit Zipper Pouch?
@leeperry6376, I totally understand. You might also want to check with your local library to see if they have a Maker Space. Some libraries offer these spaces equipped with 3D printers, which could be helpful. It’s worth looking into.
As for the compatibility of the Hakko Soldering Tip Holder with the FixHub tips, I can’t say for sure. They might fit in the pouch, but that will likely depend on your preference and setup.
За последние 24 часов: 1
За последние 7 дней: 9
За последние 30 дней: 34
За все время: 655
3 Комментариев
I would also like a storage case for the extra tips. Currently I am using the Zipper pouch that I got with Electronics Cleaning Bundle. But the extra tips are still in the "retail" packaging to prevent any damage to them. I would like something like a "chef's knifes rolling case" for them
Certa Cito
из Kurt Поделиться
i have a basic tip storage that holds 3 tips i can share if you can find someone to print it for you? it just sits on top of the battery
из EcoNut Поделиться
@econut Thanks for the offer!
That would be great :-)
из Andreas M Поделиться
