Поддержка калькулятора Texas Instruments TI-84 Plus.
Line of keys not working.
I've had my calculator for years and use it frequently. Today, an area of keys - specifically "0", "1", "4", "7", ",", "sin", "apps", "x^2", "(", ")" stopped working. All other keys work fine. I've tried restarting, system reset, and changing batteries. I don't know if it's possible water damage (I have cats) or something else.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
If a column of keys stops working that typically means it's a hardware problem. You might have success taking the calculator apart and cleaning the button side of the circuit board with isopropyl alcohol.
However, it's likely you'd also need to do a board level repair using soldering equipment. Water damage and corrosion can certainly cause issues like this.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Milo Moss буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 14
За все время: 150
