Identifying internal display ZIF Connector
Greetings,
I have a Steam Deck OLED which has a damaged surface-mount connector that connects the internal display to the device. I have no idea where to find this part, and Steam Support refused to give me the name of it. I heard from someone else that a repair tech was able to use a connector from a Surface Pro as an equivalent, but it's hard to find info on that too.
Otherwise, I'm guessing I'll have to find an equivalent based on the length, width, height, no. of pins, pitch, etc. on Mouser or something but I'm not sure what this double-decker style of pins is called that is on this flex cable (I usually work with very old electronics so I haven't seen this before), so if anyone knows what the official name for that is it'll give me one more parameter to source a replacement.
Thanks in advance.
An image of the connector can be found through the following link on Ifixit's guide to replacing the OLED screen: https://guide-images.cdn.ifixit.com/igi/...
Это хороший вопрос?
did you ever get this resolved? I am in the same boat
из Sami Abdalla A
