4-дюймовый iPhone, выпущенный в марте 2016 года, с характеристиками оборудования, аналогичными модели 6S. Доступен в цветах «серебристый», «серый космос», «золотой» и «розовое золото» с вариантами памяти 16/32/64/128 ГБ. Модели: A1662 и A1723
Bluetooth lost range after battery replacement
I just changed out my battery using a kit I bought here at iFixit. It was a bit of a struggle but I got it done. However, now when I connect it to my Bluetooth speaker it starts breaking up if it moves more than like a foot away. I think the wifi is affected too but it's hard to tell (my wifi isn't great normally). I'm a little worried I might have broken something. Should I go back in and replace the antenna or are there other troubleshooting things I should do first before I open the phone again?
Note: I have performed several hard resets but the problem seems to come back in different ways. I think it is a problem with the range of the antenna.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
You’ve bumped off or damaged the WiFi and Bluetooth antenna, which is that s shaped cable right above the battery.
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
I opened it up again and that is exactly what happened. It got caught under the battery and snapped when I was putting the battery in. Always look twice before shoving something in everyone!
из
Добавьте свой ответ
Pat буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 10
За всё время: 223
