Информация по ремонту, разборке и устранению неисправностей iPhone 15, выпущенного 22 сентября 2023 года. Оснащен 6,1-дюймовым OLED-дисплеем, системой из двух камер на 48 Мп и разъемом USB-C.
How can I replace a damaged lens
I dropped the phone a damaged one of the two lenses. The camera still works well but I’d like to replace the lens. How can I do that?
Это хороший вопрос?
Счет 3
4 Комментариев
Easiest way to replace the lens is to replace the back glass. Замена задней панели iPhone 15
You'll find plenty of options to buy it online.
из Поделиться
@seppebruyland I'm going to disagree completely with your opinion. Removing the rear glass really isn't that easy compared to just replacing a single camera lens, plus there are sensors on the back panel and you run the risk of getting non-genuine part warnings and/or losing functionality such as wireless charging, etc.
In addition, we're talking about a significant price difference as well; probably at least $50 for a quality replacement part vs. what, a couple of bucks for the camera lens?
из Поделиться
@Jerry Wheeler I understand, but I think
that finding a replacement lens of comparable quality might be a challenge. Getting the lens out without damaging the camera will require taking off the back glass anyway. I’m a bit split on this: If it was my own phone I would probably buy some cheap lens and glue it in. But someone elses phone might make me consider a black glass replacement as the end result will look a lot more factory, no glue residue etc.
из Поделиться
Finding a sapphire glass replacement is not hard. Two suppliers I use have them in stock and for a good price. Taking the lens off does not require removing the back. Ive repaired lots of lens and have never had to remove the back.
из Поделиться
Добавить комментарий
2 Ответов
Наиболее полезный ответ
If it's just the lens itself and not the glass surround the camera bump, then it's not hard to do. Get a decent hair dryer or heat gun and a pick of some sort. I use tweezers. Remove the glass pieces, replace the adhesive, then the lens. Normally this process takes about 10 minutes and it's not very expensive. I dont see the parts here on iFixit but, make sure you buy the sapphire glass replacement lens with adhesive.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
Thanks Brian. It looks like the metal ring should pick off too but is this not necessary?
из Поделиться
No, the metal ring shouldnt come up. Here is a link to a YouTube video for a 15 pro max. I wouldnt use the cutter tool he uses but, the concept is the same.
https://www.youtube.com/watch?v=QxgfkdhK...
из Поделиться
One of my camera lens has broked and the quality has of photo is decreased
Счет 0
1 Комментарий:
So replace it as described in the previous answers. Did you really need somoene to say that rather than just following the instructions already given?
из Поделиться
Добавьте свой ответ
Chris буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 14
За последние 7 дней: 106
За последние 30 дней: 437
За все время: 10,836
