Информация по ремонту, разборке и устранению неполадок смартфона POCO X3 NFC на базе Android, модель M2007J20CG. Устройство оснащено процессором Snapdragon 732G, дисплеем с частотой обновления 120 Гц, квадрокамерой 64 Мп, NFC и аккумулятором емкостью 5160 мА·ч.
Why won't it charge anymore?
My friend's phone has had it for 5 years and suddenly it won't charge. I cleaned the port with toothbrush and isopropyl alcohol and nothing. Before I did it though, I did try to charge it on 2 different chargers, a 45w and 65w, and on the 2nd it turned on from being dead and was charging for around 10 seconds before it turned off. Now, it won't display anything, only the white led on top.
Это хороший вопрос?
Счет 5
4 Комментариев
باد کردن باطری گوشی
из
Motherboard change
=== Update (08/24/25) ===
How to motherboard change
из
O celular não está ligando
из
Poco x3 ka madhur board
=== Update (02/08/26) ===
Poco x3 ka madhear board
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Hi @henryares,
Best I can find online is that the phone is designed to be charged using chargers up to 33W only.
Hopefully you haven't damaged the battery management circuit in the phone by using a 65W or even the 45W charger. You should be able to use these as normally the battery will only draw as much current as it needs to, but given that Xiaomi is being specific about it being "up to 33W" I don't know.
Perhaps check that the main flex cable between the charge port board and the mainboard is securely connected at both ends.
If it is then you could try replacing the charge port board and see if that fixed the problem.
Here's a video that shows how to replace the charge port board that may help. It will also allow you to check if the main flex cable connections are secure as well
If you decide to replace the charge port board, search online for Poco X3 charge port board, to find suppliers that suit you best.
Был ли этот ответ полезен?
Счет 2
Estava com esse problema também, consegui resolver com outro cabo flex da Sub placa
Счет 0
In the Poco X3, X3 NFC, and X3 Pro, there’s a plug-type socket that can sometimes come loose or even detach. Fixing it is pretty simple—once you remove the back casing, the job becomes much easier. All you’ll need is a Phillips screwdriver to unscrew the cover above the battery. Then, check the wide ribbon cable running over the battery to see if it’s loose. If it is, secure it—and you can thank me later.
Счет 0
Добавьте свой ответ
Henry Ares буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 19
За последние 30 дней: 145
За всё время: 2,265
