Doorbell not syncing with hub.
Hi, my doorbell won't sync with hub anymore.
I repositioned the bell and when I clicked it into the holder it was difficult to clip in. So it looks like I used too much force and the screw head that holds the bracket pressed hard against the workings inside the bell. I've tightened down the screw for clearance. Now the bell won't sync with the hub, it doesn't connect anymore. Does anyone know what part I've damaged and can it be repaired. I must have broken a connection inside. It charges ok and makes the ring sound when pressed, it just won't connect anymore. Please help.
Это хороший вопрос?
Счет 0
1 Комментарий
@gaz79543
Please post the images in your question.
Use the link in the answer below to see how to do this.
из
Добавить комментарий
1 ответ
Выбранное решение
Hi @gaz79543
Open the door bell and then check the board for any damage.
Here's a Eufy Video Doorbell 2k (Battery-Powered) Teardown guide that may help.
If you find any (or even not) post some close up images of the board (both sides) back in your question. Here's how to do this on ifixit Adding images to an existing question
iFixit Изображение
Инструкция
Сложность:
Очень просто
2 - 5 minutes
Eufy Doorbell 2k (Battery-Powered) Изображение
Инструкция
Сложность:
Умеренно
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Gaz буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 24
За всё время: 208
