Простая в использовании 35-мм зеркальная фотокамера с ручной фокусировкой. Номер модели X-370.
I think this is wrong?
My shutter button doesn’t do anything when pressed but when I pull my film advance lever the mirror flips up as if I pressed the shutter button. Anyone know how to fix this?
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Here are a few possible fixes:
1. Check the Batteries
The X-370 has an electronically controlled shutter, meaning dead or weak batteries can cause the shutter to stop working. Try replacing the two SR44, LR44, or equivalent 1.5V batteries and see if that helps.
2. Reset the Mirror & Shutter
Since the mirror flips up but doesn’t come down normally, the shutter may be stuck. Try this:
1. Remove the lens to see the mirror.
2. If the mirror is up, gently press it down with a soft tool (like a cotton swab).
3. Once the mirror is down, try pressing the shutter button again.
3. Engage and Disengage the Self-Timer
Sometimes, the self-timer gets stuck and prevents the shutter from firing. If your camera’s self-timer is engaged:
1. Wind it up and let it fully run down.
2. Then try pressing the shutter button.
4. Check the Film Advance Lever
If the lever moves but doesn’t engage the shutter, the internal mechanics may be misaligned.
Try slowly advancing the lever and pressing the shutter at different points to see if it engages.
5. Open the Bottom Plate (Last Resort)
If none of the above work, you may need to open the bottom cover (3 small screws) and inspect the mechanical linkages.
Sometimes, a spring or lever inside is stuck and can be gently nudged back into place.
If you see dirt or hardened grease, a tiny amount of lighter fluid or electronic contact cleaner can help.
If Nothing Works
The camera might need a CLA (clean, lube, adjust) from a professional repair shop. The X-370 is a solid camera, so it’s usually worth fixing if the issue isn’t too severe.
Был ли этот ответ полезен?
Счет 0
These electrically controlled shutter release involves using a magnet, which then is deenergized to create the release of the mechanicals of the shutter. Here the electromagnet bar and magnet face need to be cleaned as there’s grit or oil that’s preventing the holding force.
Review the service manual here Minolta X-370
Счет 0
Добавьте свой ответ
Michael White буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 21
За последние 30 дней: 68
За все время: 471
