Reocurring iPadOS Kernel Panic
Having this issue with my iPad Air M1.
{"bug_type":"210","timestamp":"2024-12-27 15:45:03.00 +0100","os_version":"iPhone OS 18.2 (22C152)","roots_installed":0,"incident_id":"1A9F302E-041A-411B-A477-8F2F8E9C0F46"}
"build" : "iPhone OS 18.2 (22C152)",
"product" : "iPad13,17",
"socId" : "8103",
"socRevision" : "11",
"incident" : "1A9F302E-041A-411B-A477-8F2F8E9C0F46",
"crashReporterKey" : "97fd4c732fc6f49b06d9eb5fd8c8dbd91aaa8d92",
"kernel" : "Darwin Kernel Version 24.2.0: Thu Nov 14 22:51:23 PST 2024; root:xnu-11215.62.3~1\/RELEASE_ARM64_T8103",
"date" : "2024-12-27 15:45:03.32 +0100",
"panicString" : "panic(cpu 3 caller 0xfffffe0026a9c294): SMC PANIC - ASSERT: target\/ipad13b\/target.cpp:342: 0, SMC BSC failure, spreadsheet ver(*10) 40\nS.sensor array 0 - 7 is 0x2000, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0 0x0\nF.sensor array 0 - 1 is 0x0 0x0\n\n - Misc(2) OUTBOX2 not ready\nASSERT: target\/ipad13b\/target.cpp:342: 0, SMC BSC failure, spreadsheet ver(*10) 40\nS.sensor array 0 - 7 is 0x2000, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0 0x0\nF.sensor array 0 - 1 is 0x0 0x0\n\n\nRTKit: RTKit-2758.60.101.release - Client: AppleSMCFirmware_H13-5204.60.266.ipad13b.REL\n!UUID: 2d95f501-5706-3253-ba49-ad822112ce4c\nASLR slide: 0x0000000000000000\nTime: 0x000000041fc68423\n\nFaulting task 2 Call Stack: 0x0000000000034ac0 0x0000000000034450 0x000000000003426c 0x0000000000032cb0 0x000000000002d8a8 0x00000000000230ac 0x0000000000027de4 0x0000000000030600 000000000000000000\n\nChinook ASC Async error info: \nl2c_err_sts 0x5000fbfc00000000, l2c_err_adr 000000000000000000, l2c_err_inf 000000000000000000\nlsu_err_sts 000000000000000000, fed_err_sts 000000000000000000, mmu_err_sts 000000000000000000\ndpc_err_sts 000000000000000000\n\nMailbox (0): (0)\n Inbox AKF_KIC_INBOX_CTRL = 0x00020001, AKF_KIC_MAILBOX_SET = 0x11111101\n Outbox AKF_AP_OUTBOX_CTRL = 0x00020001, AKF_AP_MAILBOX_SET = 0x00000000\n\n dir endpoint timestamp msg
Это хороший вопрос?
Счет 0
1 Комментарий:
You might find this helpful Diagnosing issues using crash reports and device logs
Have you installed any new Apps or update any? If not, I would review your Apps pulling out what you don’t need. I would also remove as much of your data you can, music, vids, pics, and anything else you have freeing up the drive.
из Поделиться
Добавить комментарий
