Руководства по ремонту, поддержка и информация по диагностике MacBook Air 13 дюймов марта 2024 года на базе однокристальной системы Apple M3. Выпущен 8 марта 2024 года, номер модели A3113.
Screen panel closing issue
I have an mba purchased in october of the last year. I have noticed today that when I close the screen, it will not remain closed at all. Is this normal or it is an issue and I need to get Apple service?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Sounds like either the uppercase has warped a bit or the lid hinges are out of alignment.
Make sure you don’t have a snap-on shell as these have tabs to hold them on the gap between which is to narrow and all you do is crack you display. I only recommend skins which are more than enough for most.
Был ли этот ответ полезен?
Счет 1
22 Комментариев:
I didn't use a shell and since I bought it, rarely I'v closed the lid, maybe at least 6/8 times. I'm a bit worryed
из
@ziobru Do you use a Keyboard protector or one of those webcam sliders?
из
I have a keyboard protector but it's very thin, I've tried to remove it, but the problem still remain
из
@ziobru - as your system is likely still under warranty I would head over to the Apple Store to see what they can do. But leave the keyboard protector at home.
из
I purchased it on the mediaworld online store and not into an Apple store. I don’t know if Apple will give me support directly. I sended today a mail to the support of the online store to understand if I can get warranty from them or I will need to go to an Apple store
из
Показать ещё 17 комментариев
Добавьте свой ответ
B1P буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 10
За всё время: 382
