Четвертое поколение умных часов Apple с опциональным сотовым модулем, выпущенное 21 сентября 2018 года.
Can't open watch
I have a Series 4 40mm SS.
I bought the iFixit kit to replace the battery. However I can not get under the screen to lift it using the scalpel. I've applied the iOpener heat mat several times, to the point the watch is too hot to handle. I just can't get enough purchase. I've tried lightly, with force, and all along the edges. Advice would be appreciated.
Это хороший вопрос?
Счет 0
Добавить комментарий
3 Ответов
I created a wood block to hold the watch as it’s just safer. The trick is to aim the knife curved edge downward between the case and crystal parting the two from each other, then once I’ve gotten the knife edge into the space I twist it in a prying action under the crystal. You do need to keep the pressure on the knife.
Был ли этот ответ полезен?
Счет 0
Use a small suction cup if you have one to lift up the display similar to phone repair
Force the blade under the screen (carefully of course)
Счет 0
I had to buy Dorco (razor) blades to get a thin enough edge to get between the case and screen.
Счет 0
Добавьте свой ответ
Ryan буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 12
За последние 30 дней: 24
За все время: 252
