Poco M4 Pro 4G Выпущен 16 марта 2022 г. Вес 179,5 г, толщина 8,1 мм Android 11, MIUI 13 для POCO Накопитель 64 ГБ/128 ГБ/256 ГБ, microSDXC
Charging problem to my phone
When I put my phone on charge it is not getting charge faster and having automatically charging on and off problem why it is happening?
Это хороший вопрос?
Счет 2
Добавить комментарий
3 Ответов
Hey there!
If I had to assume, I would say that your charging port has a bad connection to its PCB. Before you open it up to look, however, make sure you try a different cord and/or a different wall outlet to make sure they aren't the problem. I would also check your settings to see if you have "prioritized charging" or something along those lines turned on. The setting could be making your phone not charge at certain points.
If you have confirmed that everything I've listed isn't what's wrong, I would either open it to see if the charging port is bad, or even take it to a local repair shop to have it looked at.
Best of luck!
Был ли этот ответ полезен?
Счет 0
Poco m4 pro 4g speaker was filled by dust
Счет 0
When I put phone on charging charging was soo slow
Счет 0
Добавьте свой ответ
Bm amer буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 34
За всё время: 666
