Четырехъядерный процессор Intel Core i7 с тактовой частотой 2,0 ГГц, 2,3 ГГц или 2,6 ГГц (Turbo Boost до 3,8 ГГц) и 6 МБ общей кэш-памяти L3.
MacBook not turning on
Hey all! I was installing macos mavericks on my macbook, when it suddenly turned off and refused to turn back on again. The charging indicator shows that its charging thogh (the orange and green light) but isnt actually on. What can i do to fix it or what can be the cause? Thanks
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Let's try a hard SMC reset.follow this guide to Step Замена аккумулятора MacBook Pro 15" с дисплеем Retina (конец 2013 г.) now with nothing plugged in press and hold the power button for a good 15sec's this will discharge the logic board. Now carefully plug in the MagSafe charger only, the system should spontaneously restart, let it complete the process and do a clean shutdown. Now carefully reconnect the battery and with the MagSafe charger also connected see if that works if it does, shutdown and disconnect the charger and test again. If any of these fails let us know.
Был ли этот ответ полезен?
Счет 0
3 Комментариев:
Hey til what step? I think your text glitched a bit
из
I figured it out and tried your steps. Didn't work. However when i plugged the charger in and let go of the power button, it turned green, then it went back to orange
из
@zarrar_ - I if it stays Amber, the battery needs to be charged and might need replacing as well. Let it sit a good four hours, then try to turn it on then.
из
Добавьте свой ответ
Zarrar буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 14
За последние 30 дней: 26
За всё время: 210
