Информация по ремонту и диагностике неисправностей для Dell Latitude E5570. Это 15,6-дюймовый ноутбук бизнес-класса с процессором Intel Core 6-го поколения. Он был выпущен в 2016 году.
Black screen of death
So when I turn on my laptop I get greeted with a black screen, some trouble shooting I have done it trying to reinstall windows (I still saw black screen), when i press caps lock nothing happens, when I try to open bios nothing happend, i have tried reseating ram, using a differant hard drive, doing a hard reset, took out the cmos battery then put it back in, tried plugging it into moniter with hdmi and vga, nothing works,
Any help would be appreciated.
Это хороший вопрос?
Счет 0
2 Комментариев:
Does the screen turn on but not show anything or can you see the backlight on?
из
@uptempoguy the backlight is not on at all. the screen is copletely black, same as when its turned off
из
Добавить комментарий
1 ответ
@heathbrown43963 check your backlight (most likely not the issue sine you also have no pictures on an external monitor). Turn your computer on and in a darkened room, use a flashlight and shine the beam at an angle against the screen. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed.
It is possible that this is a bad BIOS. You may need to consider reflashing it. Of course, there is also a possibility that this is a failure of your GPU circuitry on your motherboard.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Heath Browning-Davies буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 9
За последние 30 дней: 21
За все время: 341
