Модель A1502 / двухъядерный процессор Intel Core i7 с тактовой частотой 2,6 ГГц (Turbo Boost до 3,1 ГГц) или 2,8 ГГц (Turbo Boost до 3,3 ГГц) и 4 МБ общей кэш-памяти L3.
Fix keybord cable before replacement
I need to replace the keyboard of my MBP because sone key stopper working and I think it’s because the connector is damnaged. Before proceed, I’ve searched here some similar questions and found also one where there is an attacched video with the needed steps. I’m looking for a written guide I can follow, but my question is, can I fix only the connector instead of replacing the whole keyboard? To do the fix I need to remote the battery and display or I can avoid? If I Remo e the battery how I will put it in place again, is there a special take I can found on Amazon that I can use?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
I have made written guides for many models but ifixit has yet to approve them.
Замена клавиатуры MacBook Pro 13" Retina Display начала 2015 года
You'll have to remove the battery to change the keyboard, as the keyboards cable is part of the keyboard, and also to get to the track pad and it's cable, I would check this cable 1st as it is replaceable, check to re connect it 1st. and also any think double sided tape should be strong enough to hold the battery in its place again afterwards.
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
The 2015 model have sone differences with the mid2014?
из
@ziobru The exact guide for the 2014 model has yet to be published by ifixit. It is the virtually same procedure anyway.
из
Добавьте свой ответ
B1P буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 6
За последние 30 дней: 32
За всё время: 281
