How to clean the mower deck
My mower won't start, how do I clean the mower deck
Это хороший вопрос?
Это хороший вопрос?
Personally, I use a pressure washer to clean the underside of the deck. You can turn the mower on its side and either use a pressure washer, or (as I did in pre-pressure washer days) use a gasket scraper or putty knife to scrape the underside of the deck. If you'd rather not turn the mower on its side, placing it up on two inverted 5 gallon pails should give you the clearance to get under there with your putty knife.
As for the starting problem, presuming this is a 120 volt plug in mower, a clogged deck could prevent starting. Short of that, be sure the plug is tight in the outlet and that there is power to the outlet.
Был ли этот ответ полезен?
За последние 24 часов: 1
За последние 7 дней: 1
За последние 30 дней: 7
За всё время: 129
