Самоходная бензиновая газонокосилка Murray® 22 дюйма, 2-в-1, с двигателем Briggs & Stratton® объемом 140 куб. см
No drive to wheels
Change the drive belt
Это хороший вопрос?
Счет 0
1 Комментарий:
The front wheel drive stopped working on my Murray 22 inch front drive mower. I couldn't get the cover off the wheel drive. I took off two big and two small screws underneath but the cover would not come off so I took off the blade, removed the 3 nuts on the engine pulley cover, found the belt slipped off the engine pulley. I took off the pulley, watch for the Woodruff key, kind of a trick to get it back into the engine pulley. The belt looked okay. The side of the plastic engine pulley may have to be replaced but I put the belt back on. Reassembled and it worked okay but I will eventually have to get the drive cover off and replace the belt. Any help here?
Jerry in Kentucky.
из
Добавить комментарий
1 ответ
Here's a page from the manual that might help. Good luck.
En 2a8a513128c1d33166c65ab81a984af2
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Dennis schweitzer буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 10
За последние 30 дней: 59
За всё время: 608
